Repair and disassembly guides for Brother printers.
wifi Direct button disabled on MFC5750
So the WI-FI Direct button seems to be disabled. Whw i push it nothing's happening, just i hear a bip sound.
Wherever I found something about this, the instructions start with "Press the wifi Direct button" but for me I press it in vain because it is inactive.
Do you know how to activate this button?
Add a comment
1 Answer
Most Helpful Answer
Hi @marcel7577
Check if the WiFi Direct option has been turned off.
On the printer go to Settings → Network → WiFi Direct → I / F Enable to either turn it on or off
Score 1
3 Comments:
I can't enter the WIFi Direct menu because it's disabled. That's exactly the problem
by
@marcel7577
Try resetting the network and check if it works after that.
Go to Settings → Network → Network reset.
by
@jayeff
I solved it. I disabled wlan and activated wifi Direct.
It took me a while to realize that on the same wifi device, wlan and wifi direct don't work at the same time...
It would have been nice if brother said that wifi direct doesn't work at the same time with wlan.
thanks
by
Add a comment
Add your answer
Marcel will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 25
All Time: 95
