Cutsor is not showing
Cursor is not working
Add a comment
1 Answer
The issue with the cursor (mouse pointer) not showing on your Lenovo XiaoXin Air 14 Plus (also known as Xiaoxin Air 14 Plus) is a common problem on Lenovo laptops, often related to the touchpad being disabled, driver glitches, or temporary software hiccups.
Try some quick checks:
  • Plug in an external USB mouse—if the cursor appears and works with it, the issue is definitely touchpad-related (not a display/graphics problem).
  • Disable "Hide pointer while typing" in Control Panel → Mouse → Pointer Options tab (uncheck the box).
  • Perform a power reset: Shut down completely, unplug the charger, hold the power button for 30–60 seconds, then plug back in and turn on.
  • Run Lenovo Vantage app (pre-installed on most Xiaoxin models): Go to System Update and install any pending updates, especially for hardware/drivers.
Add a comment
Add your answer
Avika Shrivastav will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 24
All Time: 156
