Repair information, service manuals, and troubleshooting help for refrigerators manufactured by LG Electronics.
LG GF-5D712BSL Door Issue - Temperature Changing
When ever i open the left hand door with the control panel and ice maker on it, the control panel flickers and beeps and when clsoes sometimes the fridge temperature setting changes. What would cause this?
Add a comment
1 Answer
Most Helpful Answer
Hi @gavinsoute23788
Seems like a loose harness cable connection on the Control panel pcb.
It's strange that when searching for information regarding parts or a service manual for the model number you posted, all results always end up showing parts lists and a service manual for an LG GR-J24FWxx refrigerator.
Given that your model may be based on this model, here's the GR-J24FWxx service manual Go to p.89 to see how to remove the control panel so that you can check if the cable connections are secure.
Score 1
1 Comment:
Ok thanks will check this!
by
Add a comment
Add your answer
Gavin Souter-Robertson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 65
