Apple's eighth-generation smartwatch, released on September 16, 2022.
How can I Replace the microphone
Hi,
The microphone on my apple watch has stopped working.
When i try to record something and play it back , i can only hear a hissing noise.
audio output works fine, so i believe the issue is with the mic itself.
Since the warranty has expired, i was thinking about replacing it myself,
Add a comment
1 Answer
Chosen Solution
Before you crack open your watch, first see if you can even find the combo microphone/speaker unit. I gave up fixing these years ago when parts where just not available other than salvaged from junkers.
While we have a few guides for this series Apple Watch - Series 8, we don't have anything that deep. The best we have is an older models teardown so you can see about what you'll need to get down to even to pull the old unit out Apple Watch Series 6 Teardown jump to the end the thin part at top left is the part.
Add a comment
Add your answer
Hedrick Albert Matamorosa will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 24
All Time: 140
