Up to 20% off select tools
Explore repair and additional information for the Whirlpool WRF540CWB* refrigerator, a non-compact, non-built-in model released in 2014, without an ice maker or through the door dispenser. This page covers information for model numbers matching the pattern WRF540CWB*.
Freezer not staying cold
Have a WRF540CWBM00 and we noticed the freezer not staying cold and ice maker not working turned the ice maker off and freezer started cooling installed new ice maker and turned it on and freezer started heating up again now the freezer only gets to around 5 degrees and setpoint is -4 refrigerator stays at set point
Add a comment
1 Answer
Hi @alanottinger
Is the compressor running nearly continually trying to drive the temperature in the freezer down to the set temperature?
Here's the tech sheet for the refrigerator.
Follow the procedure to initiate the Service Test mode and perform Service Test #142 - Freezer thermister and check. Also Service test #152 - Freezer food door state, just to confirm that the door is closed.
Add a comment
Add your answer
Alan Ottinger will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 25
All Time: 191
