The wifi button is not available
if i got to connect to the internet using wifi it doesn’t show the option to connect to the wifi
Add a comment
Most Helpful Answer
Hi @dariannjoku
If there's no WLAN device listed in Device Manager, check the WLAN device has not been disabled in BIOS.
Go to BIOS → Power Management → Wireless radio control → Control WLAN radio
Score 1
Add a comment
possibly a dead WIFI board inside, this site should have everything you need.
https://www.parts-people.com/
Add a comment
@dariannjoku since you have not told us which OS you are using, I assume you are using some kind of Windows. If so, use the device manager and check under Network Adapter to see if your adapter still shows. If it does, I would start by removing the old driver and installing a new driver. If it does not show in your Device Manager, check if there is an unknown device which could be the network card, just not being properly identified. Again, try to install that with a new network driver.
If none of that works you will need to check the network card itself. Use the Latitude 5289 2 In 1 Owner's Manual which does include the troubleshooting and maintenance part for your computer. It is possible that this is a bad card but check everything else first. Make sure that your antenna cables are still properly connected etc. Page 14 of the manual shows you how to remove/replace the card.
Add a comment
Add your answer
DARIAN NJOKU will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 11
All Time: 121
