The Lenovo IdeaPad 1-15ALC7 is a 15.6-inch laptop designed for everyday computing, featuring AMD Ryzen 7000 series processors and upgradeable storage. Model: IdeaPad 1-15ALC7.
Backlight not working what do I do
recently my laptop had fallen off my bed when I woke up and it knocked the screens loose from the part connecting my screen to the actual computer and now the screen turns on however you need a flashlight to do see anything? What do I do
Add a comment
Chosen Solution
Hi @seanmcgowan
In order of best case to worst case possibility:
  • Loose EDP cable connection on the motherboard or the LCD screen.
Here's the hardware maintenance manual for the laptop. Go to p.53 (59 of 66 pdf) in the manual to view the procedure to remove the EDP cable. This will allow you to check if it is still securely connected to the motherboard. On p.50 (56 of 66 pdf) it shows how to remove the LCD screen. You don't have to remove the LCD screen, just check if the EDP cable is secure.
  • Damaged EDP cable where it passes through the hinge from the lower case to get to the LCD screen in the lid.
If the cable is damaged search online for 5C10S30543 (touch screen) or 5C10S30353 (non touch screen) to find suppliers that suit you best.
Here are some images showing the relevant schematic for the backlight power circuit and also the boardview showing the location of the fuse as it possibly won't be marked on the motherboard.
entire board view showing where the fuse is
zoomed in view showing the fuse location in more detail
(click on images)
  • Faulty LED backlight circuit in the LCD screen.
If this is the case, the screen will have to be replaced as it cannot be repaired. Usually the Lenovo part number for the LCD panel can be found on the back of the panel. Search online for the part number, to find suppliers that suit you best. The HMM shows how to remove the LCD panel
Score 3
1 Comment:
You are a life saver. I routed the cable wrong and it got pulled when closing the laptop causing the fuse to blow. I thought I had ruined the new screen.
thank you so much for the schematics
by
Add a comment
Your laptop likely has a damaged or disconnected display backlight, which is common after a fall. Since the image is visible only with a flashlight, the screen itself is working but the backlight or its cable is not. First, power off the laptop and avoid using it further. If you’re comfortable opening it, check the display cable near the hinge—it may be loose or partially unplugged. If reseating the cable doesn’t help, the backlight or inverter (on older models) may be damaged. In most cases, the fix is replacing the screen or display cable at a repair shop.
Score 1
Add a comment
Add your answer
Sean Mcgowan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 18
Past 30 Days: 87
All Time: 625
