LG shows no signal
shows no signal even after following instructions other tv's are connected to wifi
Your LG TV displaying "No Signal" typically means the issue is with the current input source (like HDMI from a cable box, gaming console, streaming device, or antenna), not the TV's Wi-Fi connection. Since you mentioned other TVs are connected to Wi-Fi (and presumably working for streaming), and you've already tried some instructions, this points to a problem with the external signal/input rather than internet/apps.
Try a soft reset on the TV: Go to Settings > General > Reset to Initial Settings (this won't delete apps if signed in, but back up if needed).
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 93
All Time: 781
What is the make and model number of the TV? Does the TV screen turn on at all?
by teardown-er
Yes it turns on displays a LG with a 3d cube around it under that is says no signal
by Steve Lafferty
@stevelafferty
Have you tried using different signal sources e.g. HDMI, RF, AV or cables?
What have you tried?
by jayeff
