Samsung announced the Galaxy S23 lineup at their "Unpacked" event on February 1, 2023. The new Galaxy Book3 and Galaxy Book3 Pro series of laptops were also announced
My network is not working properly
My signal keeps going down, sometimes I have no network at all. Have tried reseting network settings, restarting the phone, changing to a new sim and nothing comes to work. What can I do to fix it?
Score 2
3 Comments
Is your phone able to connect to WIFI? Are other people's phones with the same cell provider able to connect with a stronger signal to your cell service?
by
Yes the wifi works as normal, and also my sister has the same provider as I have but hers works fine
by
I have personally replaced 2 5g antennas and did the typical network resets, sims etc no fix. I noticed certain areas you would have strong signal and others not so much. I discovered it was a communication issue with the cellphone and towers. So here is a fix I discovered:
Go to Settings, Connections, mobile networks, network operators and toggle to on to allow phone to connect to towers automatically. Hope this helps.
by
Add a comment
Chosen Solution
On a Samsung S23 Ultra, unstable network after SIM changes usually points to software, carrier, or antenna issues. First, update One UI and Android fully. Then go to Settings → Connections → Mobile networks and set Network mode to 5G/LTE/3G auto. Try turning VoLTE and Wi-Fi Calling off temporarily. Check APN settings with your carrier and reset them if needed. Test the phone in Safe Mode to rule out app interference.
Score 1
6 Comments:
I have tried all of does except safe mode as it doesn't show any on my phone
by
I'm experiencing the same problem and have replaced the SIM card, E-Sim, etc. I've reset the phone to factory settings, but the problem persists. It often says "emergency calls only" and only when I have Wi-Fi does it work halfway decently.
by
same phone same exact issue, immediately after updating to ui 8.5. phone was flawless. so many people have this problem but no fixes?!
by
I'm also experiencing the same problem even after doing the necessary trouble shootings which were mentioned
by
@nanimaisaac I have personally replaced 2 5g antennas and did the typical network resets, sims etc no fix. I noticed certain areas you would have strong signal and others not so much. I discovered it was a communication issue with the cellphone and towers. So here is a fix I discovered:
by
Show 1 more comment
Add a comment
même problème pour moi
perte régulière du réseau
si je suis chez mes parents, mon S23 ultra posé sur la table a coté du Xiaomi 15T pro de ma femme, le mien 0 barre de signal, celui de ma femme 3 barres.
il ne bascule même pas en 4g, ca me coupe le réseau direct, alors qu'avec mon vieux S9+ aucun problème.
Add a comment
I’d also check whether the problem is actually the phone or the carrier coverage in the places where it happens. Since you’ve already tried a network reset, another SIM, and restarting, compare the S23 Ultra with another phone using the same carrier from the exact same spot. If the other phone keeps a stable connection while the S23 drops to zero bars, that points more toward the handset, modem firmware, or antenna.
It’s also worth checking which carrier your SIM is actually using and whether that network has reliable coverage in your area. A useful reference is the website because it has guides covering Philippine mobile networks, carrier comparisons, coverage, and network-specific issues. The site is focused specifically on Philippine networks, so its information is most relevant if you’re using a Philippine SIM.
If the issue follows the S23 Ultra regardless of location, I’d run Samsung Members diagnostics and have the phone checked for an antenna or modem fault. If it only happens in certain locations, carrier coverage or local network congestion is much more likely.
Add a comment
Add your answer
Kcs will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 80
Past 30 Days: 329
All Time: 3,367
