The Galaxy A20e is a midrange slate Android smartphone released by Samsung in May 2019. Identifiable by model numbers SM-A202F/K.
Why is my microphone not working
When I record it doesn't record my voice it records the background
Add a comment
1 Answer
Quick Fixes:
  1. Clean the microphone hole at the bottom of your phone - debris/dust often causes this
  2. Remove your case - protective cases can block the mic opening
  3. Restart your phone - hold Power + Volume Down for 7-10 seconds
Test which mic is faulty:
  • Dial #0# → select "Loopback" → test both microphones
  • If only the top mic works, that confirms the bottom mic (used for recording) is faulty
Software fixes to try:
  • Boot in Safe Mode (Power → long-press "Power off" → tap "Safe mode") - if it works here, a third-party app is the problem
  • Check app permissions: Settings → Apps → [Recording App] → Permissions → Microphone
  • Wipe cache partition (Power off → hold Power + Volume Up → select "Wipe cache partition")
If nothing works: The bottom microphone module likely needs replacement. This is a common hardware failure on the A20e and requires repair at a Samsung service center. The part is relatively inexpensive to replace.
Add a comment
Add your answer
Thamzin Deep will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 54
