A vaporizer for dry herbs.
Why is my OLED screen glitching?
After 3 months having this vape, the screen started to ocasionally glitch, now it is unsufferable. I opened to check for anything wrong with it's circuit and wasn't able to identify the problem with the OLED display. I tried cleaning it with isopropyl alcohol, but no sucess.
Have anyone had this issue or can guess how to fix it?
Score 1
Add a comment
1 Answer
The display issue is likely due to the flat cable, which naturally forms a poor bend angle. I replaced mine and used hot glue to give the cable a proper bend radius. Bought the display on AliExpress and it worked.
2 Comments:
I see. Do you mind telling me the specs of the cable you bought? I have 0 knowledge of flat cables and OLED pannels.
by
I replaced my OLED display with this:
https://pt.aliexpress.com/item/100500673...
"0.69 Inch OLED Display 96x16 Pixels PG-9616TSWD Blue White L9616TSWC 14P IIC I2C Port Eleaf Istick Rim C PICO 75W TS100 TS08"
by
Add a comment
Add your answer
Erico Fadel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 40
All Time: 168
