Repair, disassembly, and troubleshooting information for the Xbox Series X, Microsoft's 4K gaming console. The Xbox Series X was released alongside its companion console, the Xbox Series S, on November 10th, 2020.
Capacitors next to VRM M86925 Mosfets
What values do these capacitors have?
Add a comment
1 Answer
I have no idea. I do, however, think I have an idea as to how you can find out. If you have a magnifying glass handy, and ideally also a flashlight, you could angle the light so that it doesn't glare too much, and then use the magnifying glass to read the values. I'll assume that you have some idea about what the sort of values you're looking for and they mean, so I won't go too in depth. If you don't, that's fine, too. Just leave a comment and I'll explain. Unfortunately, at the moment I can't say much else as the photo you have here isn't good enough to tell which parts are the capacitors. If you could verify that, and maybe also provide a more zoomed in image, it would also help. Good luck!
Add a comment
Add your answer
Daniel will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 27
All Time: 96
