Up to 20% off select tools
Released in November 2017, the Oppo F5 is the first smartphone to use an 18:9 display instead of 16:9. In spite of having a 6.0-inch screen, the F5's width is similar to the 5.5" display with 16:9. Models CPH1723 and CPH1727.
How to change lcd
Teach me how to change lcd
Add a comment
Most Helpful Answer
Hi Kyle,
I wasn't able to locate any iFixit-style step by step instructions, but as @ruggb mentioned, there are plenty of YouTube videos available. I went through this one, and it should be suitable for showing you how to make your repair.
Oppo F5 CPH1725 LCD (Display) Replacement. How to change Broken Display Oppo F5?? - YouTube
I do have a couple of criticisms of this video based on experience. First, too much force was used removing the battery; as you'll see from the video he managed to bend it significantly in the process of taking it out. If that was my phone, I would not have reused that battery; bending them can damage the internals and possibly result in a fire. If the battery gives you that much resistance taking it out, try adding some 90% or higher concentration isopropyl (rubbing) alcohol under the battery to help loosen the adhesive. That will make the adhesive non-reusable, so you could also try some heat on the screen, which will also help loosen the adhesive. A plastic playing card slid under the battery can separate the adhesive from the battery too; just be sure not to use metal tools that can damage the battery.
Another thing I'd suggest is that once the screen is off, be sure to clean off the old glue with your rubbing alcohol before applying glue. The old glue can keep you from getting a good seam to help secure and seal the phone against liquids.
Finally, before applying the glue, I suggest you plug in the new screen, pop the battery in temporarily and turn it on to verify the replacement works before you go to the trouble of gluing it down. Best practice is to either secure the screen with rubber bands or put some weight on the phone until the glue dries.
Hopefully that tells you everything you need to know to get your screen replaced! As you work, take lots of pictures and once you're done you can use those to create your very own iFixit guide to the Oppo F5 Screen Replacement. It's easy, fun, and will earn the appreciation of the repair community for those who come after you with the same problem.
Create a new Guide - iFixit
Good luck, and be sure to come back and let us know how it all turns out!
Score 2
Add a comment
have you tried YouTube? Obviously not as there are a few videos there.
Add a comment
Add your answer
Kyle Sagaran will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 30
All Time: 204
