The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
Controllers/joycons disconnecting, not synching
Im having intermittent connectivity with controllers (joycon, pro controller, 3rd party) on my switch, I have verified that the antennas, both BT and Wifi are firmly corrected and event tested continuity from the antenna board to the switch MB, WIFI seems to work OK although I dont have a real way to test for continuous wifi connection. Issue persist either docked or undocked.
Most of the time the controllers wont connect, and when they do, its only for a short while, and usually just after restarting and only after connecting to a wifi network.
Wireless controller IC seems fine and no damaged capacitors/resistors nearby, also checked capacitors near APU and they are OK.
Add a comment
1 Answer
Most Helpful Answer
Hi!
Are you sure that the bluetooth controller is fine?
As how you are describing it I would say that there is something going on with the antenna’s..
I would replace some parts and see how that goes. New antenna’s are not that expensive and easy to replace and test.
If that’s not it, then it must be motherboard related.
I think there is not much left to try… sorry.
Score 1
4 Comments:
Yes, tested controllers on a different switch, waiting for a replacement BT antenna, just was hoping to get pointers of any possible SMT components that could cause the issue, appreciate the comment
by
Alright, will check the antenna’s with new ones first and see how that goes. If that fails it’s probably the bluetooth IC on the board..
by
Update, tested it with a new antenna and got worse results, controllers not detected at all, also tried soldering the antenna cables directly to the PCB and got same results, reballing/replacing the main wireless IC PCA is beyond my skillset tho so I think this is as far as I can go, rip
by
Ahh, wish I had better news :(. You can replace the motherboard, or take the parts out that are working and sell it..
by
Add a comment
Add your answer
Zeroth will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 32
All Time: 102
