Repair guides and documentation for the Google Pixel 6a with 5G smartphone. Released in July 2022.
Dull yellowish screen after replcing battery
Problem when finished replacing battery in Pixel 6a with a dull, rather yellow screen. Help please.
Score 1
Add a comment
Hello! There are a few steps to try and fix this. Check if Night Light is on in the quick actions, I'd also go through and check all of your display calibration settings to see if you have accidentally turned on any color correction modes or a different display mode (Eg. "Natural" to "Adaptive"). If it's hardware related, you may have overheated the panel, if it's uneven or in a particular spot this is likely. Also try reseating the display connector or checking for water damage.
1 Comment:
It happened to me, too. Nothing obvious and I didn't notice it until I've assembled everything back. Any yellowish is uniform, not in particular spot, didn't overheat the screen. The only thing that I can think of is connector, but then again it seemed clicking correctly. I might eventually get a new screen adhesive and check the connector.
by
Add a comment
I think this might have happened - damaged or removed filter
Add a comment
Add your answer
Colin Ruck will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 13
All Time: 71
