Replacing seals on the back hatch.
What kind of seals and glue do I use to replace the seals on the back hatch?
@lewis66549 this is a bit confusing. Are you not going to replace the seal with something from an auto part store? Something like a Liftgate Weatherstrip - GM (15174843) To attach it, you really should not need to have to use adhesive. The seal has a channel that will surround and grab the edges of the sheet metal to stay in place. Now, if you do want to use adhesive (in case your metal seam is not quite what it should be) use something like the weather strip adhesive made by 3M or Permatex.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 112
