Up to 20% off select tools
A more affordable, purely handheld version of the Nintendo Switch game console, with integrated Joy-Con controllers and a slightly smaller screen. Released September 20, 2019.
Volume up button doesn't work.
I got a new cat recently who required some training, and unfortunately, I think she urinated on my switch. The only issue I've noticed since cleaning it is that the volume up button no longer works. The volume down button works, the power button works, everything else seems fine, I just can't turn the volume up, and there's no setting in the Switch itself to adjust volume either. I have not yet tried anything to fix it because I'm quite inexperienced working on electronics myself, but if there is a way to fix it myself, I'll certainly try. The button does not appear to be stuck; it presses down and up normally, but it just doesn't do anything.
Add a comment
1 Answer
Most Helpful Answer
Hi there!
Yes, those buttons are replaceable!
Your in luck I guess :)!
You can follow this guide: Nintendo Switch Lite Screen Replacement (from step 41 all the way till step 43).
So you dont need to remove the motherboard or other components!
If you have any questions, please let us know!
Score 1
Add a comment
Add your answer
Kai Hayden will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 21
All Time: 216
