Up to 20% off select tools
Nintendo Switch Lite Screen Replacement
Views: 81K
View statistics:
Past 24 Hours:
82
Past 7 Days:
507
Past 30 Days:
2,291
All Time:
80,736
Comments: 97
93 comments on steps, 4 guide comments.
Go to guide comments
Completed: 32
32 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the screen on your Nintendo Switch Lite. The screen consists of the LCD and digitizer. If you're only replacing the LCD, follow this guide. If you're only replacing the digitizer, follow this guide.
The Nintendo Switch Lite uses JIS screws, which are slightly different than Phillips. We don’t recommend using Phillips drivers for JIS screws; however, iFixit Phillips bits are specifically designed to be compatible with JIS screws. If you use a non-iFixit Phillips driver, you risk stripping the screws.
Replacement adhesive is required to complete this guide.
Note: Although removing the joysticks and buttons isn’t required, it makes this repair much easier.
    1. Nintendo Switch Lite Screen Replacement, Remove the back panel screws: step 1, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Before beginning this repair, make sure that the device is completely turned off.
      • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
      Ask FixBot
    2. Nintendo Switch Lite Screen Replacement, Remove the top and bottom back panel screws: step 2, image 1 of 2 Nintendo Switch Lite Screen Replacement, Remove the top and bottom back panel screws: step 2, image 2 of 2
      • Use a JIS 00 driver or an iFixit Phillips driver to remove the following screws securing the back panel:
      • Two 3.6 mm-long screws on the top of the device
      • Two 3.6 mm-long screws on the bottom of the device
      • To prevent these tight screws from stripping, apply firm downward force, work slowly and try a different screwdriver if the screws won't come out.
      Ask FixBot
    3. Nintendo Switch Lite Screen Replacement, Release the clips securing the back panel: step 3, image 1 of 2 Nintendo Switch Lite Screen Replacement, Release the clips securing the back panel: step 3, image 2 of 2
      • Insert an opening tool into the left speaker grille on the bottom of the device.
      • Twist the opening tool to release the clips securing the back panel.
      • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
      Ask FixBot
    4. Nintendo Switch Lite Screen Replacement, Continue releasing the clips around the device: step 4, image 1 of 2 Nintendo Switch Lite Screen Replacement, Continue releasing the clips around the device: step 4, image 2 of 2
      • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
      Ask FixBot
    5. Nintendo Switch Lite Screen Replacement, Twist to release the clips: step 5, image 1 of 2 Nintendo Switch Lite Screen Replacement, Twist to release the clips: step 5, image 2 of 2
      • Insert an opening tool into the right speaker grille on the bottom of the device.
      • Twist the opening tool to release the clips.
      Ask FixBot
    6. Nintendo Switch Lite Screen Replacement, Slide and pry around the corners: step 6, image 1 of 2 Nintendo Switch Lite Screen Replacement, Slide and pry around the corners: step 6, image 2 of 2
      • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
      Ask FixBot
    7. Nintendo Switch Lite Screen Replacement: step 7, image 1 of 2 Nintendo Switch Lite Screen Replacement: step 7, image 2 of 2
      • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
      Ask FixBot
    8. Nintendo Switch Lite Screen Replacement, Remove the back panel: step 8, image 1 of 3 Nintendo Switch Lite Screen Replacement, Remove the back panel: step 8, image 2 of 3 Nintendo Switch Lite Screen Replacement, Remove the back panel: step 8, image 3 of 3
      • Lift the bottom edge of the back panel, opening it like a book.
      • Remove the back panel.
      Ask FixBot
    1. Nintendo Switch Lite Screen Replacement, Remove the shield plate: step 9, image 1 of 1
      • Use a JIS 00 driver or an iFixit Phillips driver to remove the four screws securing the shield plate:
      • Three 3.1 mm screws
      • One 4.5 mm screw
      Ask FixBot
    2. Nintendo Switch Lite Screen Replacement: step 10, image 1 of 3 Nintendo Switch Lite Screen Replacement: step 10, image 2 of 3 Nintendo Switch Lite Screen Replacement: step 10, image 3 of 3
      iFixit Thermal Putty
      $9.95
      Buy
      • Use a spudger or your fingers to lift the shield plate up and out of the device.
      • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal putty.
      • Remove the shield plate.
      • Clean off the old thermal putty from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal putty to the heat sink before reassembly.
      Ask FixBot
    1. Nintendo Switch Lite Screen Replacement, Disconnect the interconnect cable: step 11, image 1 of 3 Nintendo Switch Lite Screen Replacement, Disconnect the interconnect cable: step 11, image 2 of 3 Nintendo Switch Lite Screen Replacement, Disconnect the interconnect cable: step 11, image 3 of 3
      • Be gentle when lifting this flap—it's easy to accidentally break off.
      • Use your fingernail or an opening tool to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
      Ask FixBot
    2. Nintendo Switch Lite Screen Replacement: step 12, image 1 of 2 Nintendo Switch Lite Screen Replacement: step 12, image 2 of 2
      • Don't use metal tweezers! They can short-circuit the ribbon cable/connector and damage your device.
      • Use a spudger or a pair of non-conductive (nylon or ceramic) tweezers to slide the interconnect cable out of its connector on the motherboard.
      Ask FixBot
    3. Nintendo Switch Lite Screen Replacement, Disconnect the battery: step 13, image 1 of 2 Nintendo Switch Lite Screen Replacement, Disconnect the battery: step 13, image 2 of 2
      • Use the point of a spudger to pry the battery connector, as close to the connector as possible, straight up and out of its socket on the motherboard.
      • During reassembly, wait until after you connect the interconnect cable (above) before connecting the battery.
      Ask FixBot
    1. Nintendo Switch Lite Screen Replacement, Remove the heat sink: step 14, image 1 of 1
      • Use the flat end of a spudger or your fingers to carefully peel up the foam that's lightly adhered to the fan.
      • The foam only needs to be peeled back enough to clear the fan.
      Ask FixBot
    2. Nintendo Switch Lite Screen Replacement: step 15, image 1 of 1
      • Use a JIS 00 driver or an iFixit Phillips driver to remove the three 3 mm screws securing the heat sink to the motherboard.
      Ask FixBot
    3. Nintendo Switch Lite Screen Replacement: step 16, image 1 of 3 Nintendo Switch Lite Screen Replacement: step 16, image 2 of 3 Nintendo Switch Lite Screen Replacement: step 16, image 3 of 3
      • Use a spudger or your fingers to lift the heatsink up and off of the motherboard to remove it.
      • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
      • Clean off the old thermal paste from the heat sink and CPU using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
      Ask FixBot
    1. Nintendo Switch Lite Screen Replacement, Remove the game card reader and headphone jack: step 17, image 1 of 2 Nintendo Switch Lite Screen Replacement, Remove the game card reader and headphone jack: step 17, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the game card reader cable's ZIF connector.
      Ask FixBot
    2. Nintendo Switch Lite Screen Replacement: step 18, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the seven 3.1 mm screws securing the game card reader and headphone jack.
      Ask FixBot
    3. Nintendo Switch Lite Screen Replacement: step 19, image 1 of 3 Nintendo Switch Lite Screen Replacement: step 19, image 2 of 3 Nintendo Switch Lite Screen Replacement: step 19, image 3 of 3
      Buy
      • Use a pair of tweezers or your fingers to carefully lift the game card reader and maneuver it to the left to slide the cable out of its connector.
      • Remove the game card reader and headphone jack.
      Ask FixBot
    1. Nintendo Switch Lite Screen Replacement, Remove the right trigger button assembly: step 20, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the two 4.5 mm screws securing the right trigger button assembly to the motherboard.
      Ask FixBot
    2. Nintendo Switch Lite Screen Replacement: step 21, image 1 of 2 Nintendo Switch Lite Screen Replacement: step 21, image 2 of 2
      • Remove the right trigger button assembly.
      Ask FixBot
    3. Nintendo Switch Lite Screen Replacement: step 22, image 1 of 2 Nintendo Switch Lite Screen Replacement: step 22, image 2 of 2
      Buy
      • Use a pair of tweezers or your fingers to remove the right trigger button assembly's rubber pad if it didn't stay attached to the button assembly.
      Ask FixBot
    4. Nintendo Switch Lite Screen Replacement, Disconnect the antenna cables: step 23, image 1 of 3 Nintendo Switch Lite Screen Replacement, Disconnect the antenna cables: step 23, image 2 of 3 Nintendo Switch Lite Screen Replacement, Disconnect the antenna cables: step 23, image 3 of 3
      • Use the point of a spudger to pry the black antenna cable coaxial connector straight up off its socket on the motherboard.
      • Repeat the same process for the white antenna cable.
      Ask FixBot
    5. Nintendo Switch Lite Screen Replacement, Disconnect the fan cable: step 24, image 1 of 1
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the fan cable's ZIF connector.
      Ask FixBot
    6. Nintendo Switch Lite Screen Replacement: step 25, image 1 of 2 Nintendo Switch Lite Screen Replacement: step 25, image 2 of 2
      • Use a pair of tweezers to slide out the fan cable from its connector on the motherboard.
      Ask FixBot
    7. Nintendo Switch Lite Screen Replacement, Disconnect the screen cable: step 26, image 1 of 2 Nintendo Switch Lite Screen Replacement, Disconnect the screen cable: step 26, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the screen cable's ZIF connector.
      Ask FixBot
    8. Nintendo Switch Lite Screen Replacement: step 27, image 1 of 2 Nintendo Switch Lite Screen Replacement: step 27, image 2 of 2
      • Use a pair of tweezers to slide the screen cable out of its connector on the motherboard.
      Ask FixBot
    9. Nintendo Switch Lite Screen Replacement, Disconnect the digitizer cable: step 28, image 1 of 2 Nintendo Switch Lite Screen Replacement, Disconnect the digitizer cable: step 28, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
      Ask FixBot
    10. Nintendo Switch Lite Screen Replacement: step 29, image 1 of 2 Nintendo Switch Lite Screen Replacement: step 29, image 2 of 2
      • Use a pair of tweezers to slide the digitizer cable out of its connector on the motherboard.
      Ask FixBot
    11. Nintendo Switch Lite Screen Replacement, Disconnect the right joystick cable: step 30, image 1 of 2 Nintendo Switch Lite Screen Replacement, Disconnect the right joystick cable: step 30, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the right joystick cable's ZIF connector.
      Ask FixBot
    12. Nintendo Switch Lite Screen Replacement: step 31, image 1 of 2 Nintendo Switch Lite Screen Replacement: step 31, image 2 of 2
      • Use a pair of tweezers to slide the right joystick cable out of its connector on the motherboard.
      Ask FixBot
    13. Nintendo Switch Lite Screen Replacement, Remove the motherboard assembly: step 32, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the following six screws securing the motherboard:
      • Three 4.5 mm screws
      Ask FixBot
    14. Nintendo Switch Lite Screen Replacement: step 33, image 1 of 3 Nintendo Switch Lite Screen Replacement: step 33, image 2 of 3 Nintendo Switch Lite Screen Replacement: step 33, image 3 of 3
      • Insert a spudger in the gap between the frame and the motherboard and lift the motherboard up and out of its recess.
      • Remove the motherboard assembly.
      Ask FixBot
    1. Nintendo Switch Lite Screen Replacement, Remove the right joystick: step 34, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the two 3.5 mm screws securing the joystick.
      Ask FixBot
    2. Nintendo Switch Lite Screen Replacement: step 35, image 1 of 2 Nintendo Switch Lite Screen Replacement: step 35, image 2 of 2
      • Use your fingers to remove the joystick.
      • There is a thin black gasket around the hole where the joystick pokes through the frame. Try not to disturb this gasket as you remove the joystick.
      Ask FixBot
    1. Nintendo Switch Lite Screen Replacement, Remove the left speaker module: step 36, image 1 of 2 Nintendo Switch Lite Screen Replacement, Remove the left speaker module: step 36, image 2 of 2
      Buy
      • Use a pair of tweezers or your fingers to pull the left speaker cable straight up and out of its socket on the daughterboard.
      • Do not pull from the wires, or else you risk ripping the wires off the connector.
      Ask FixBot
    2. Nintendo Switch Lite Screen Replacement: step 37, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the 4.5 mm screw securing the left speaker module.
      Ask FixBot
    3. Nintendo Switch Lite Screen Replacement: step 38, image 1 of 3 Nintendo Switch Lite Screen Replacement: step 38, image 2 of 3 Nintendo Switch Lite Screen Replacement: step 38, image 3 of 3
      • Use your fingers to lift the speaker module up and out of its recess to remove it.
      • Part of the speaker module sits underneath a delicate ribbon cable. Take care not to snag the speaker module on the cable as you remove it.
      Ask FixBot
    4. Nintendo Switch Lite Screen Replacement, Disconnect the motherboard interconnect cable: step 39, image 1 of 2 Nintendo Switch Lite Screen Replacement, Disconnect the motherboard interconnect cable: step 39, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
      Ask FixBot
    5. Nintendo Switch Lite Screen Replacement: step 40, image 1 of 2 Nintendo Switch Lite Screen Replacement: step 40, image 2 of 2
      • Use a pair of tweezers to slide the motherboard interconnect cable out of its connector on the daughterboard.
      Ask FixBot
    6. Nintendo Switch Lite Screen Replacement, Disconnect the screen and volume button cables: step 41, image 1 of 2 Nintendo Switch Lite Screen Replacement, Disconnect the screen and volume button cables: step 41, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flaps on the two ribbon cable ZIF connectors.
      Ask FixBot
    7. Nintendo Switch Lite Screen Replacement: step 42, image 1 of 3 Nintendo Switch Lite Screen Replacement: step 42, image 2 of 3 Nintendo Switch Lite Screen Replacement: step 42, image 3 of 3
      • Use a pair of tweezers to slide the daughterboard screen cable out of its connector on the motherboard.
      • Repeat this procedure for the volume buttons cable.
      Ask FixBot
    8. Nintendo Switch Lite Screen Replacement, Remove the volume buttons: step 43, image 1 of 2 Nintendo Switch Lite Screen Replacement, Remove the volume buttons: step 43, image 2 of 2
      • Use a pair of tweezers or your fingers to remove the volume buttons.
      Ask FixBot
    9. Nintendo Switch Lite Screen Replacement, Disconnect the joystick cable: step 44, image 1 of 2 Nintendo Switch Lite Screen Replacement, Disconnect the joystick cable: step 44, image 2 of 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the left joystick cable's ZIF connector.
      Ask FixBot
    10. Nintendo Switch Lite Screen Replacement: step 45, image 1 of 2 Nintendo Switch Lite Screen Replacement: step 45, image 2 of 2
      • Use a pair of tweezers to slide the left joystick cable out of its connector on the daughterboard.
      Ask FixBot
    11. Nintendo Switch Lite Screen Replacement, Remove the left trigger button assembly: step 46, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the two 4.5 mm screws securing the left trigger button assembly.
      Ask FixBot
    12. Nintendo Switch Lite Screen Replacement: step 47, image 1 of 2 Nintendo Switch Lite Screen Replacement: step 47, image 2 of 2
      • Remove the left trigger button assembly.
      Ask FixBot
    13. Nintendo Switch Lite Screen Replacement, Remove the daughterboard: step 48, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the following four screws:
      • Two 4.5 mm screws
      • Two 6 mm screws
      Ask FixBot
    14. Nintendo Switch Lite Screen Replacement: step 49, image 1 of 2 Nintendo Switch Lite Screen Replacement: step 49, image 2 of 2
      • Use your fingers to lift the daughterboard up and out of its recess to remove it.
      Ask FixBot
    15. Nintendo Switch Lite Screen Replacement, Remove the left joystick: step 50, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the two 3.5 mm screws securing the left joystick.
      Ask FixBot
    16. Nintendo Switch Lite Screen Replacement: step 51, image 1 of 3 Nintendo Switch Lite Screen Replacement: step 51, image 2 of 3 Nintendo Switch Lite Screen Replacement: step 51, image 3 of 3
      • Use the flat end of a spudger to lift the joystick up and out of its recess.
      Ask FixBot
    1. Nintendo Switch Lite Screen Replacement, Unfasten the midframe assembly: step 52, image 1 of 1
      • Use a JIS 000 driver or an iFixit Phillips driver to remove the four screws securing the midframe assembly:
      • Three 2.5 mm screws
      • One 6 mm screw
      Ask FixBot
    2. Nintendo Switch Lite Screen Replacement, Remove the midframe assembly: step 53, image 1 of 3 Nintendo Switch Lite Screen Replacement, Remove the midframe assembly: step 53, image 2 of 3 Nintendo Switch Lite Screen Replacement, Remove the midframe assembly: step 53, image 3 of 3
      • Use a spudger to pry the midframe assembly up until you can grip it with your fingers.
      • Grip the midframe assembly and pull up to remove it.
      Ask FixBot
    3. Nintendo Switch Lite Screen Replacement, Remove the remaining buttons: step 54, image 1 of 2 Nintendo Switch Lite Screen Replacement, Remove the remaining buttons: step 54, image 2 of 2
      • Remove any remaining buttons that are loose in the frame.
      Ask FixBot
    4. Nintendo Switch Lite Screen Replacement, Heat the left edge: step 55, image 1 of 1
      • Flip the frame over so the screen is facing up.
      • Heat an iOpener and apply it to the left edge of the screen for two minutes.
      • Alternatively, you can use a hair dryer on the Low heat setting.
      • If you're using a hair dryer, only heat the screen a few seconds at a time or you may warp the plastic shell.
      Ask FixBot
    5. Nintendo Switch Lite Screen Replacement, Insert an opening pick: step 56, image 1 of 3 Nintendo Switch Lite Screen Replacement, Insert an opening pick: step 56, image 2 of 3 Nintendo Switch Lite Screen Replacement, Insert an opening pick: step 56, image 3 of 3
      • Lightly bend the left side of the frame away from the screen to create a gap in the bottom left corner.
      • If you're having difficulty creating a gap, reapply a heated iOpener for two minutes and try again.
      • Insert an opening pick in the gap.
      • Don't insert your pick more than 3 mm to avoid damaging the screen.
      Ask FixBot
    6. Nintendo Switch Lite Screen Replacement, Slice the left adhesive: step 57, image 1 of 2 Nintendo Switch Lite Screen Replacement, Slice the left adhesive: step 57, image 2 of 2
      • Throughout this repair, don't insert your pick more than 3 mm to avoid damaging the screen.
      • Slide the opening pick along the left edge.
      • Leave the pick inserted in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    7. Nintendo Switch Lite Screen Replacement, Heat the top edge: step 58, image 1 of 1
      • Apply a heated iOpener to the top edge of the screen for two minutes.
      • You can also use a hair dryer, but remember not to heat the screen more than a few seconds at a time.
      Ask FixBot
    8. Nintendo Switch Lite Screen Replacement, Slice the top adhesive: step 59, image 1 of 2 Nintendo Switch Lite Screen Replacement, Slice the top adhesive: step 59, image 2 of 2
      • Rotate the opening pick around the top left corner.
      Ask FixBot
    9. Nintendo Switch Lite Screen Replacement: step 60, image 1 of 2 Nintendo Switch Lite Screen Replacement: step 60, image 2 of 2
      • Slide the opening pick along the top edge.
      • Leave the opening pick inserted in the top right corner.
      Ask FixBot
    10. Nintendo Switch Lite Screen Replacement, Heat the right edge: step 61, image 1 of 1
      • Apply a heated iOpener to the right edge of the screen for two minutes.
      Ask FixBot
    11. Nintendo Switch Lite Screen Replacement, Slice the right adhesive: step 62, image 1 of 2 Nintendo Switch Lite Screen Replacement, Slice the right adhesive: step 62, image 2 of 2
      • Rotate the opening pick around the top right corner.
      Ask FixBot
    12. Nintendo Switch Lite Screen Replacement: step 63, image 1 of 2 Nintendo Switch Lite Screen Replacement: step 63, image 2 of 2
      • Slide the opening pick along the right edge.
      • Leave the opening pick inserted in the bottom right corner.
      Ask FixBot
    13. Nintendo Switch Lite Screen Replacement, Heat the bottom edge: step 64, image 1 of 1
      • Apply a heated iOpener to the bottom edge of the screen for two minutes.
      Ask FixBot
    14. Nintendo Switch Lite Screen Replacement, Slice the bottom adhesive: step 65, image 1 of 2 Nintendo Switch Lite Screen Replacement, Slice the bottom adhesive: step 65, image 2 of 2
      • Rotate the opening pick around the bottom right corner.
      Ask FixBot
    15. Nintendo Switch Lite Screen Replacement: step 66, image 1 of 2 Nintendo Switch Lite Screen Replacement: step 66, image 2 of 2
      • Slide the opening pick along the bottom edge.
      Ask FixBot
    16. Nintendo Switch Lite Screen Replacement, Separate the adhesive: step 67, image 1 of 2 Nintendo Switch Lite Screen Replacement, Separate the adhesive: step 67, image 2 of 2
      • Grip the frame and push up on the underside of the screen's left edge to separate the adhesive securing it.
      Ask FixBot
    17. Nintendo Switch Lite Screen Replacement, Remove the screen: step 68, image 1 of 3 Nintendo Switch Lite Screen Replacement, Remove the screen: step 68, image 2 of 3 Nintendo Switch Lite Screen Replacement, Remove the screen: step 68, image 3 of 3
      • The digitizer cables prevent the screen from being lifted straight up from the frame.
      • Lift the left side of the screen to a 45-degree angle and remove it.
      • If the screen is still stuck to the frame, slide an opening pick around the perimeter and try again.
      • During reassembly, follow this guide to replace the screen adhesive.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
32 other people completed this guide.
Author
with
Spencer Day
210,806 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
4 Guide Comments
Thanks for your guide - it was very helpful, first time I took screen off without breaking it off :). I also bought the iFixit kit with the heat pad. I can now see that the trick was not so much a lot of heat, but heat evenly along the whole side
Angelo Felix - Reply Share
omg you are a lifesaver thank you so much
Adien Richards - Reply Share
Hi, looked at your post. Wow! What’s a detail and organizational post. Thanks
But it is too much for a 65 years old lady to do it. I have to stop playing my animals crossing after 6 years playing it. Sad to let it go my town crying
Palm Trees - Reply Share
@palmtrees71290 I would take it to a repair shop with the parts and have them replace it having the parts will reduce the cost of the repair
then you will only have to pay for the labor
Liam Kriews - Reply Share
Past 24 Hours: 82
Past 7 Days: 507
Past 30 Days: 2,291
All Time: 80,736
