Up to 20% off select tools
Lenovo LOQ 15IAX9 with Intel i5-12450HX, up to RTX 4060 GPU, 15.6″ FHD 144 Hz display, up to 32 GB DDR5, PCIe Gen4 SSD, 60 Wh battery, and full I/O including HDMI 2.1 and USB-C.
How cleaning colling fans?
I want to clean my laptops fan
Score 1
1 Comment
Clean colling fan
by Share
Add a comment
1 Answer
Most Helpful Answer
Hi!
You can follow Lenovo's official guide in their Hardware Maintenance Manual to take of the lower chassis (see page 30).
Then you'll have direct access to the fan. You can remove the dust with a small brush, some pressured air, or if you are a bit careful you could use a vacuum cleaner on lowest setting. Note! That having the fans spinning a lot when blowing/sucking can be bad for them, so gently keep a finger on the fan to keep it from spinning.
Good luck!
Score 2
Add a comment
Add your answer
fun codm will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 77
All Time: 1,026
