A portable beginner sewing machine with a sturdy metal frame and a front loading bobbin.
Why does the machine get stuck?
When i try to use it the needle gets stuck inside the bobbin case. The bobbin case doesn’t work and is stuck
2 Comments:
I cleaned out the bobbin case and have put everything back as the diagram and the top thread gets tangled and the needle won’t come up
=== Update (05/08/26) ===
How do I fix it
by
@audreyjoyc49032 are you having the same problem with your sewing machine as the OP (Original Poster)? What make and model is your sewing machine?
by
Add a comment
1 Answer
check witch way bobber is put in, they do have a timing belt. does it do it on straight stich
Add a comment
Add your answer
Pooja shrestha will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 29
All Time: 287
