Released on July 28th, 2017, The New Nintendo 2DS XL is a technologically-improved remodel of the 2DS handheld. It is the ninth and last redesign of the Nintendo DS line, The console is much larger than the original 2DS model and adds all the features of the updated 'New 3DS' line of systems, minus the ability to play games in stereoscopic 3D on the top screen.
problems with hinge/spine of 2ds?
so when i try to move the top screen of my new 2ds backwards after repairing and swapping the shell it doesnt close fully on the back and has trouble when i try to put the top screen flat in line with the bottom ive tried opening and cleaning it i also reseated the top lcd
Add a comment
1 Answer
This usually happens when the hinge isn’t aligned correctly after the shell swap. Even if the screen and LCD are re-seated, the top housing won’t close or sit flat if:
1. The hinge barrel isn’t fully rotated into its locked position.
It needs to “click” into place. If it’s off even a little, the lid will resist closing.
2. The ribbon cable has tension or is twisting inside the hinge tunnel.
A slight twist is enough to keep the top shell from lining up.
3. One of the hinge tabs isn’t sitting in the shell track.
The system will close on one side but not the other.
Quick fix:
Open the system back up, rotate the hinge fully until it locks, check that the ribbon sits smoothly with no sharp bends, and then reassemble.
No new parts needed unless the hinge barrel is cracked.
If you want, I can tell you exactly how to check alignment step-by-step.
1 Comment:
that would be nice thanks
by
Add a comment
Add your answer
God o will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 56
All Time: 532
