Released September 16th, Apple's "smaller" flagship smartphone features a 6.1" ProMotion OLED, a triple-lens rear camera system, 5G, and a newly designed "Dynamic Island" around the front-facing camera and top sensors. Successor to the iPhone 13 Pro.
Cameras not working after screen replacement
I had to replace my phone screen at a mall repair kiosk today after I dropped it. Everything seems normal except for the notification shown in the picture and the camera. It shows as a black screen and is completely nonfunctional. The strange thing is that if I open the camera on other apps it works fine on the selfie camera! When I try to switch to the back camera it freezes up. I’ve gone through all the fixes for a black camera screen and nothing worked. It’s updated to the latest iOS, I’ve restarted it, and even reset all settings. The camera isn’t broken because it works on other apps… what could be causing this and how do I fix it? Very frustrating!
Add a comment
1 Answer
Most Helpful Answer
The camera should be paired to the motherboard on your phone; I'm wondering if somehow due to the screen replacement something got messed up with the pairing. Did they use a genuine Apple screen, or is it aftermarket? I assume they didn't replace the camera, right?
Anyway, assuming you are on iOS 18 or later, I'd suggest running the Repair Assistant app and see if it will pair the camera for you again. It's not always clear exactly how iOS will react to an unpaired part nowadays; sometimes it works and other times it won't.
Score 1
3 Comments:
मेरे सेल फ़ोन का मदरबोर्ड चला गया है
by
@prempateljat wrote: My cell phone's motherboard has gone bad.
What makes you think the motherboard has "gone bad"? What is the phone doing or not doing? Motherboard repair is generally far beyond the capability of most of us; it requires specialized equipment and expertise. If you're just looking for a guide to replacing the motherboard, you could use this one.
https://www.nadiemellamagallina.com/en/m...
by
@prempateljat, आपको ऐसा क्यों लगता है कि मदरबोर्ड "खराब हो गया है"? फ़ोन क्या कर रहा है या क्या नहीं कर रहा है? मदरबोर्ड की मरम्मत करना आम तौर पर हममें से ज़्यादातर लोगों की क्षमता से बाहर होता है; इसके लिए खास उपकरणों और विशेषज्ञता की ज़रूरत होती है। अगर आप सिर्फ़ मदरबोर्ड बदलने के लिए कोई गाइड ढूंढ रहे हैं, तो आप इसका इस्तेमाल कर सकते हैं।
by
Add a comment
Add your answer
Jenny Shearley will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 46
All Time: 170
