Lenovo LOQ 15IAX9 with Intel i5-12450HX, up to RTX 4060 GPU, 15.6″ FHD 144 Hz display, up to 32 GB DDR5, PCIe Gen4 SSD, 60 Wh battery, and full I/O including HDMI 2.1 and USB-C.
Usb ports not working
Good day I trust you are well. I have the above mentioned laptop. I use a cooling pad as well as accessories for gaming, my two rear usb ports suddenly stopped working. I have gone through the drivers as well as softwares and checked that everything is correct, usbs are still dead. Any advice? Kind regards
Score 1
1 Comment
Dell USB port not working
by
Add a comment
1 Answer
Most Helpful Answer
Hi @wouterbred35891
Connect a mobile phone or USB mouse to one of the USB ports and check if the phone starts to charge or the mouse's laser light turns on.
If they don't go to Device Manager and check that the USB Power Management setting of "Allow the computer to turn off this device to save power" is unchecked.
To get to Device Manager in Win10/11 press the Win key + x key (both together) and select the Device Manager link in the options menu box that opens.
When in Device Manager scroll down to Universal Serial Bus Controllers → click on > symbol to expand the entry list → right click on a USB Root Hub entry → Properties → Power Management
If the checkbox is checked uncheck it → OK
Do this for all the USB Root Hub entries shown in the list.
When completed, close all open windows and then restart Windows in the normal manner and check if the USB ports now work OK
Score 1
Add a comment
Add your answer
Wouter Bredenkamp will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 60
All Time: 605
