Released by Samsung in March 2016. Model SM-G930, Versions: G930F (Global); G930FD (Global; Southeast Asia); G930W8 (Canada).
Several S7 died completely
So i bought 6 s7 for cheap and most of them had good screens when inspecting. I also had one that was freezing when heating up so i have 7 in total. So i charged one that was in the best condition and got stuck on charging logo and after force restarting got serious artifacts on the motherboard. Opened the phone, screen still works. Removed wireless coil, speaker, antenna. Still ok. After switching to a working motherboard screen stops working. I tried everything but got no result. Same thing with every phone. When charging they slightly heat up after 10 - 15 min. So how can i make atleast 1 working phone? please help
Add a comment
1 Answer
Hi @mishaneyu
Here's the Troubleshooting manual and a parts list that may help to find out and fix what's wrong.
Follow the troubleshooting flowcharts to see how far you get with each flowchart. Use the Ctrl + f keyboard function (if using Windows PC) to find the location of the board components mentioned in the flowcharts in the board layout diagrams in the manual. You will have to zoom in a lot - 500%+, to see them.
If there's a faulty component, find its part number in the parts list and then search online for Samsung (insert part number) to find suppliers of the part. You'll need smd soldering skills and tools to replace any faulty board components
5 Comments:
Even with 100% working boards it still doesnt work
But i can try to reflow solder by heating the boards up
by
@mishaneyu
Did you follow the "Power On" troubleshooting flowchart on p.7?
What does it show?
by
battery above 3.8v? - no. tried a 5000mah 4.0v cell, still the same.
Sound and vibration ok? - no sound and vibration
Check the voltage level at
R7027 while pressing power - cant do that
the thing is that even a working motherboard stops working after changing it
by
@mishaneyu
Since you can't check the voltage on R7027 then you haven't proved that there isn't a problem with the power button flex cable as you haven't mentioned that you changed it.
That's not part of the motherboard but is connected to it.
by
so i checked the button flex with a multimeter and it was ok
also a few days ago i had access to a lab psu and some motherboards were pulling 00.00 amps or 00.03 amps always but other were pulling 00.00 at start but after pressing the power button they were pulling around 00.25 amps and i tested all power button flexes
i will try to buy a working s7 with a broken screen to see the cause
by
Add a comment
Add your answer
mishaneyu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 190
