Up to 20% off select tools
Repair guides, disassembly, and troubleshooting information for the HP EliteBook 845 G8, an AMD business laptop released by HP in December of 2020. Identified by model number 1W3K7AV.
How to replace the keyboard
The key base is damaged and the keyboard needs to be replaced. How to replace the keyboard module
Score 2
Add a comment
1 Answer
Most Helpful Answer
Hi @ccteuzukx07kce5
Here's the maintenance and service guide for the laptop.
It shows how to completely disassemble the laptop as this is what is required to replace the top cover/keyboard assembly.
On p.74 (84 of 111 pdf) of the manual it has the part numbers for all the keyboard assemblies that can be used for the laptop. The keyboards are country specific and also feature specific i.e backlit, not backlit, backlit for privacy models.
Search online for the part number applicable to your particular model variant. to find suppliers that suit you best. Usually the part number can be found somewhere on the underside of the top cover/keyboard assembly if you wish to verify that you're ordering the correct one.
Score 1
Add a comment
Add your answer
春雷 张 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 120
All Time: 1,150
