The PSP 300x was released in the U.S. on the 15th of October 2008. Repair of this device requires only common tools.
My button pad stoped working, why?
it worked allright until i stoped playing with it, some months passed and when i turned the psp on again the buttons stoped working, the d-pad works correctly and everything else too, does anyone have the same issue and know how to solve it??: Thanks
Add a comment
1 Answer
Your PSP-3000’s face buttons stopped working because the button contact sheet is dirty, the ribbon cable is loose, or the button board has corrosion. The D-pad still works because it uses a different circuit. Cleaning the contacts or reseating the ribbon cable usually fixes the issue; replacing the button board is the next step and is cheap.
1 Comment:
To add: here is a guide: PSP 300x Motherboard Replacement
Please check step 18 till 20 (they explain here how to replace the input board).
by
Add a comment
Add your answer
Tiago will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 33
All Time: 137
