Repair, disassembly, and troubleshooting information for the itel S23 Android smartphone, model S665L. It features a 6.6-inch HD+ display, 50 MP rear camera, USB-C charging, and 5000 mAh battery.
Why is the phone touching it self
Why is my phone touching it self
Score 1
Add a comment
You can try restarting your phone and perhaps even boot into safe mode, but my guess is those things probably won't help; generally when we see the phenomenon commonly known as "ghost touch", it means the delicate connections between the glass the digitizer is printed on and the flex cable leading to the motherboard have been disrupted or damaged, allowing electrical noise onto the signal lines. The phone's processor then incorrectly interprets that electrical noise as touches.
Unfortunately, those connections are not repairable so the only solution is to replace the screen. Yours appears to be readily available online and is inexpensive. Here's a video guide showing you how to replace it.
Itel S23 (S665L) Screen LCD Display Replacement - Display Change - Itel S23 Repair - YouTube
Add a comment
Why my phone touching it self
1 Comment:
The answer to your question is the same as my original answer, and the fix for it is the same as well.
by
Add a comment
Add your answer
abdulhamiedmuhammadmouckhtari will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 65
All Time: 175
