Repair documentation and information for the Google Pixel 4a 5G. Released on October 29th, 2020. Model number: G025E
I this battery safe to use?
Hello, my google pixel 4a 5g had its display broken and im about to fix it soon, so recently I was bored so I opened it up to inspect it from the inside for any other damage and to clean the camera glass from the inside since it had some dirt, but after removing the back cover I found out the battery was slightly deformed from the impact, I attached some photos of the battery from the front and the back, keep in mind those photos are after I used a roller to flatten it a little and for the past year or so the battery was dented like that but I kept using the phone and cycling the battery (charge/discharge) because I still used it by mirroring its screen to my PC and I didn't face any problems with the battery, any help is appreciated!
Score 1
Add a comment
1 Answer
Most Helpful Answer
Any physical damage to a Li battery makes them no longer safe to use. Regardless that it is working, and irrespective of the fact that it may continue to work fine for years. These batteries are safe until there is physical damage, or bulging. Then they are not. This is not something up for debate, you use this battery at your own risk of damage or injury.
Still having trouble deciding?
Imagine that this belongs to the phone of your grandmother. You put it all back together and say it's fine now, fixed. She is so happy that her awesome grand child can fix things like a magician, she is so proud of you. Each day you think about that battery, is it really safe?
Score 1
Add a comment
Add your answer
Abdou Bouguerra will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 91
