How do I fix the bottom left opening hinge
how do i fix the bottom left opening hinge it has popped the bottom rectangle panel above the speakers,
Add a comment
1 Answer
Most Helpful Answer
Hi @tylorbjornson
Here's the maintenance and service guide for the laptop series that should help.
It shows the procedure to safely disassemble the laptop so that you can access the hinges to find out what the problem is.
If it's a faulty part - hinge, lower case etc, that is the problem and needs replacing, there a parts list in the guide.
Search online for (insert wanted part number) only to find suppliers that suit you best.
Score 2
Add a comment
Add your answer
Tylor Bjornson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 205
