Up to 20% off select tools
Repair guides and disassembly information for the Victus series of gaming laptops by HP.
Mouse pad is stuck
My mouse pad is stuck and the left click is constantly pressed which makes the pad unusable
Score 1
Add a comment
1 Answer
Most Helpful Answer
@ghost47490 start off by checking and adjusting the settings for your touchpad.
Through Windows Settings:
  • Press Windows key + I to open Settings.
  • Go to Devices and select Touchpad from the left-hand menu.
  • Adjust Touchpad sensitivity using the dropdown menu.
  • You can also customize gestures, scrolling and zoom settings here.
Through Control Panel:
  • Open the Control Panel.
  • Go to Mouse.
  • Click the Touchpad tab (this may vary depending on your driver) and find the options to adjust sensitivity or other settings.
If none of that will make a difference I would consider removing and checking the touchpad for and physical damage and/or replacing it. Use the HP Victus Maintenance And Service Guide and on page 59 it tells you how to work on it.
Score 1
Add a comment
Add your answer
Ghost will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 48
All Time: 872
