Repair guides, disassembly, and troubleshooting information for the Google Pixel 9 Pro Fold foldable smartphone, announced August 2024. Direct successor to the Pixel Fold.
pixel 9 Fold wont charge
I was using the phone when a question mark appeared, so I rebooted the phone. The question mark disappeared, but one hour later it appeared again. I rebooted it again, but this time it didn’t get past the Google logo. I then flashed Android 15 using the Google Android Flash Tool, but it still didn’t go past the Google logo. Now, it won’t even show the Google logo. I plugged in a cable that displays charging wattage, and it doesn’t go above 1W, so I assume it’s not charging
the question is the fallowing, i plan on buyin the 2 batteries and and USB Port board, whould this fix my issue??
Score 1
Add a comment
1 Answer
Most Helpful Answer
Issues like this can be trick to diagnose, but you may be on the right track. Charge doesn't exceed 1 watt, so it could be the charge port, but I would expect if it was the port for it to be drawing no wattage or even less than 1 watt that's still 200 mA at 5 volts, which says something is using power. But could just be the batteries.
Have you tried charging wirelessly? Wireless charging would bypass the USB port so it could rule that out as a point of failure.
When you say a question mark appeared, like the phone crashed to just that? Or there was a question mark in the battery meter?
Score 2
4 Comments:
The question mark on the battery meter. on the little icon.
by
@samirhunte67017 That means battery isn't recognized. So I think battery would be the way to go on this. Let us know how you make out!
by
This Reddit thread speaks to this "won't turn on" and battery icon issue https://www.reddit.com/r/PixelFold/comme...
by
there is a new extended warranty that covers this issue.
by
Add a comment
Add your answer
Samir “HunterHN” Dubois will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 45
All Time: 444
