SSD replacement and self-tapping screws
I've got a launch model Steam Deck and I'm considering swapping up from 256GB to 2TB on the internal SSD. I remember the initial Valve-provided video suggests not opening the Deck as that will likely disrupt the cooling airflow due to using self-tapping screws on the original case.
Should I be replacing the front and back panels at the same time if I want to replace the SSD, in order to avoid this potential cooling problem?
