Isopropyl Alcohol under iPad screen?
I was removing the iPad Pro 11 screen by using Isoproply alcohol and notice that it liquid has gone inside the lcd. Anyidea how i can fix it? See the attached image.
It looks like you over did the ISO and flooded the gap between the cover glass and the display. At this point you'll need to take the display off fully following this guide iPad Pro 11" 1st Gen Screen Replacement. Then using compressed air blow along the edge on the far side to push the ISO out as best as you can. Just be careful with your air source as most compressors use oil which will spatter fine droplets onto the surfaces. Don't use canned air here as it to could make a mess. I like using nitrogen see if a local medical supply house can rent you a small bottle.
The other option is just replacing the assembly. These are a bit tricky to open up and sadly you may have some stains.
Thank you. I left the iPad as it and after a few weeks, the alcohol marks have been wiped out significantly without any air blowing. It still has some stain left that is visible, but much better than before.
@irepairman - A little heat will speed things up, but as it evaporates it will stain. The method with the air pushes the bulk out before it concentrates residual solids in the alcohol.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 54
All Time: 386
