The infotaintment system does not shutdown
Very often the Infotaintment system does not shutdown when the ignition key is removed and sometime the display comes up with a Touch controller error. I have tried many times to clear the fault by disconnecting the battery and have to disconnect the battery over night at times so that it does not drain the battery. Is this an easy fix or will I have to go to a recognised Mitsubishi garage to may it sorted.
1 Comment:
Hi @johnalexan60992
What is the model and year of the vehicle?
Are any other features still active after the ignition key is removed, e.g. exterior lights etc.?
Normally only the horn, interior lights, any remote access features e.g. doors, engine start etc and the alarm system are powered when the ignition is turned off.
by
Add a comment
