The Shark Rocket IX141 is a cordless vacuum cleaner made by SharkNinja. This vacuum has powerful suction specially designed for pet hair cleanup.
Why is there no suction
There are no blockages, the filters are clean, the roller is turning. But there is no suction. It worked yesterday before I cleaned it. Now it is clean and it doesn't work
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hello @laney89560
The fact that it stopped working right after cleaning the canister could hint at something that happened during the process. I imagine you have done it several times and are very familiar with all the pieces that have to go back inside the vacuum after a cleaning but do you notice any gaskets / seals / rubber rings or parts that help create suction missing from the canister or around the canister area? Something that could have accidentally detached / unglued / snapped while emptying the canister?
Alternatively, do you notice anything that might have gotten stuck where all the parts along the vacuum snap / click together? Or any damaged / cracked plastic that allows air to enter the system at a place where it shouldn't?
Score 1
Add a comment
Add your answer
Laney will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 25
All Time: 233
