Repair guides, support, and troubleshooting information for the 2022 13-inch MacBook Air, featuring Apple's M2 SoC. Released on July 15th, 2022 and identified by model number A2681.
This makes no sense!
Hi all, really hoping I can get some help here!
So, in a nutshell, My MacBook won't turn on without being connected to power, and it only connects to power if you unplug the charger from the wall, disconnect the MagSafe charger, then plug both in. Once it boots up it's always showing the date as Thursday 1st April at 8pm, and it says the battery is always at 85% charged. But when I disconnect the charger, the laptop dies, and I have to go through the process again. System info says my battery condition is normal and it's only done 71 cycles so I have no idea. any help would be great!
3 Comments:
Let's get a bit of deeper info. Install this gem of an App CoconutBattery take a snapshot of the Apps main window and past it here so we can see it. If you can click on the battery info button as well. With that we should be able to figure what's happening.
by
Hey Dan, everything looks to be fine, shows battery charge at 84.1% and battery health at 95%. Full charge capacity 4,336 mAh, Design capacity 4,563mAh, 71 charge cycles. does say charging with is 0mW if that stands out?
by
@c53dgx8yju3rgxe - Yes! The zero charge is one element. But it would be easier just seeing the full image with all of the data.
by
Add a comment
1 Answer
It sounds like your MacBook isn’t getting proper power from the battery despite it showing as “normal.” The issue likely stems from a faulty battery connection, a defective charging circuit, or a failed SMC (System Management Controller). Try resetting the SMC and NVRAM, then test again. If that doesn’t help, open the MacBook and check the battery connector for loose contacts or corrosion. The constant April 1st date indicates loss of real-time clock power—another sign the battery isn’t providing voltage to key circuits. Replacing the battery or checking the logic board’s power IC may be necessary to fix the problem.
2 Comments:
It's best to try to isolate down the fault than throwing so much at the wall to see what sticks. Clearly it's a power issue but where? Which of the many areas would you focus in on?
by
Rashmi on an MacBook Air m2 2022 you cannot reset the SMC, I have tried rebuilding and everything and I still have the same issues
by
Add a comment
Add your answer
janesboy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 38
All Time: 395
