ON/OFF button not clicky anymore
My 4 year old Sennheiser headphones started acting weird a few months back. The on/off button is no longer feeling clicky and requires some extra effort to push.
Regardless of push time, in 9/10 cases the headphones enter pairing mode. In the 1/10 cases I pushed the button at just the right angle to avoid it.
Upon opening them, I realised that the actuating part of the button (the electronic bit) definitely is mot as clicky as the volume up one and experimenting with a thin screwdriver bit made me realise it's a game of chance with 2/10 presses entering pairing mode and 8/10 working just right. The deciding factor was pressure. There is no blockage or problem I can identify with the exterior plastic button.
Is there anything I can do to fix it? Part of me doesn't want to accept it but it seems the actuator is soldered and not replaceable without significant investment in equipment.
Score 1
Add a comment
1 Answer
@serbandan what you are describing sounds like an internally damaged switch Use a multimeter and probe the switch. Set your meter in ohm mode and hold the probes to the switch contacts. Now, when you press the switch you should see a decrease/increase when you activate the switch On/Off. If you do not, or if it is positional, your switch has failed. Only remedy would be to replace that.
2 Comments:
thanks, but what model of switch should I use?
by
@beargrills did you check to make sure it is the switch? Let us know the dimensions of your switch so we can try to help you find a replacement.
by
Add a comment
Add your answer
Dan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 43
All Time: 458
