Repair guides, disassembly, and troubleshooting information for the first generation Sony PlayStation 5 DualSense controller, successor to the DualShock series. Identified by model number CFI-ZCT1W and motherboard model BDM-010.
PS5 DualSense Controller Triangle Button Stopped Working
Hi,
My son dropped my controller a few times and all of a sudden the triangle is not working very well. Sometimes it works, sometimes it doesn't. I tried cleaning it up from the outside and I'm a bit sceptical about opening it as I might just make it stop working completely. Does anyone have experienced something like that? R2 trigger is also in the same condition (sometimes it works, sometimes it doesn't).
Add a comment
1 Answer
Most Helpful Answer
Hi there!
Can you still press them in? How does the button feel? Still "Clickable"?
If not, you might want to clean everything inside (with isopropyl alcohol) and replace the rubber.
Guide: Sony DualSense Controller Buttons Replacement - iFixit Repair Guide (till step 33).
If that doesn't work, then you need to replace the button circuit membrane... There is no guide for it, yet. But you can follow the same guide to get there.
Regarding the R2, try cleaning first! If that doesn't work, then you might want to replace the trigger assembly..
Guide: Sony DualSense Controller Trigger Assembly Replacement - iFixit Repair Guide
Please let us know what worked or not!
DualSense Trigger Assembly Image
Guide
Difficulty:
Moderate
1 - 2 hours
DualSense Buttons Image
Guide
Difficulty:
Moderate
1 - 2 hours
Score 2
2 Comments:
Hello! Yes, I can still press the button and sometimes it works but for some reason it just stops working now and then.
I will try with your first option and write here if that actually worked or not. Thanks for the tip. Hopefully I won't break it :')
by
Alright, yes then cleaning would be the first thing to do! Hopefully the controller will remain intact. Good luck with the repair :)!
by
Add a comment
Add your answer
Ricardo MVG will be eternally grateful.
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 89
All Time: 1,011
