Up to 20% off select tools
The Kobo Nia was released on 21 July 2020. It has a 6-inch E-Ink display at 1024 x 758 pixels, with a density of 212 ppi.
Rubber Power button cover replacement
My N3060 NIA has a rubber membrane covering the power button. The membrane on my KOBO is so worn out that I have removed it. I can still turn the unit on using a tooth pic or match stick. Can I get a replacement rubber membrane/power button cover?
1 Comment
I have this problem too, but I can no longer turn it on using a tooth pick. Can someone please post an image of what the back of the motherboard is supposed to look like?
Thanks
by Share
Add a comment
Chosen Solution
I have the same problem did you find a solution ?
Score 1
3 Comments:
Still no solution except that i had the rubber cover removed and I turn it on with a wooden match stick You can see the on/off button when the rubber membrane is removed.
by Share
Could you let me know how on/off button of the Kobo Nia works. I see a small back piece but cannot locate ean on/off switch
by Share
@gregscott64950 Having the same issue, the rubber membrane has gone but do not see a way to switch the Kobo Nia on/off
by Share
Add a comment
Get the rubber membrane out of there, the use a wooden stir stick or wooden nail'cutical' stick.
Mine has worked fine for over a year using this meathod.
1 Comment:
Simply push the black button.
by Share
Add a comment
Add your answer
Greg in Aurora Canada will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 81
All Time: 562
