Repair and disassembly guides for Samsung printers.
Samsung M2020W printer not turning on
Hello
My printer is a Samsung M2020W model.
Unfortunately, it has encountered an error in the printer formatter board.
At first, I unplugged the device's input cable several times and then plugged it back in. The device turned on and printed without any problems.
If I unplugged the printer, I had to do it again to turn it on.
It has now reached a point where it will no longer turn on.
Currently, when I plug the cable into the power, when I press the power button on the printer, it turns on and then turns off immediately.
If you can help me repair the device, please guide me.
Add a comment
1 Answer
Chosen Solution
Hi @golzarkit
Here's the service manual that may help.
Go to p.87 to view the M2020 connection diagram and check if all the voltages being supplied by the SMPS & HVPS (power supply board) are OK or not.
Score 2
Add a comment
Add your answer
golzar kit will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 38
All Time: 184
