The Toshiba Chromebook CB35-A3120 is a 13.3 inch, 1366x768 screen designed for home and educational use.
Why is the LED light blinking while charging
The Chromebook is blinking on the LED light as it charges and continues to do so and when I unplug it it turns off as it's not charging at all
Add a comment
Most Helpful Answer
Your Chromebook issue points to a charging or battery fault. First, try a hard reset by holding Refresh + Power for 10 seconds while plugged in. If it still shuts off when unplugged, the battery may be dead or disconnected. Check the battery connection inside (if accessible). If reseating doesn’t help, you likely need a battery replacement. If under warranty, contact support; otherwise, take it to a repair center.
Score 1
Add a comment
Hi @lemuel48770
Most likely the battery has failed and needs to be replaced.
Here's a video that shows what to do.
Search online for PA5171U-1BRS to find battery suppliers that suit you best.
Add a comment
Add your answer
Lemuel will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 15
All Time: 175
