The Denon AVR-1909 is a 7.1 channel A/V receiver released as part of the 2008/09 lineup of Denon receivers. It is in the upper-middle of the lineup, and is the least expensive receiver in the lineup to feature 1080p upscaling and high-definition audio decoding.
My receiver automatically shut off.
My receiver turns on, but in under a minute, it automatically shuts off. What would cause this, and what is the solution to fix it?
Score 2
2 Comments
Hi @jonverbeck
When the receiver shuts off, is the Standby LED flashing quickly i.e. on/off every 0.5 seconds or more slowly i.e. on/off every 2 seconds?
by
The standby light flashes about every .5 seconds after the receiver automatically shuts down.
by
Add a comment
1 Answer
Most Helpful Answer
Hi @jonverbeck
A .5 seconds error code is an ASO/DC protection code that indicates a problem either with the speakers, either shorted wiring, wrong impedance speakers connected etc or a problem with an amplifier associated with the audio output to the speakers i.e. excess current flow detected.
Here's the service manual that may help.
Score 2
2 Comments:
Originally, I did have the proper speakers attached, and this error occurred. I then tried it with nothing attached, and it still gives the same error. the receiver only stays on for approximately 4-5 seconds.
If there is a short somewhere, where might it be and/or how can I identify it and fix it?
by
@jonverbeck
See the No Power troubleshooting flowchart on p.23
If the answer to "Is there a short circuit between the speaker terminals and the ground?" is NO check for component damage around both the audio amps on the amp board - see p.155 for the schematic
by
Add a comment
Add your answer
Jon Verbeck will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 137
