Ipad touchscreen and home button not working
The home button nor the touch screen are working, and when i turn it on, its glitching and moving by itself.
I'm guessing you've got a couple of problems. With the digitizer unglued from the frame, that means the flex cables could be susceptible to damage. If pressed for an opinion, it sounds like the home button cable may be torn, which means you can kiss Touch ID goodbye since Apple is the only one who can pair a new home button and they don't fix iPads.
The ghost touch situation may be a little more hopeful though. It is possible the one of the digitizer cables is also damage which could account for your issues, but it's also possible the insulation between the digitizer and the frame has been damaged, allowing stray signals to come in and be interpreted as touch inputs. The digitizer replacement guide specifically mentions that possibility when installing a new touch screen and has a suggestion how to fix the problem.
iPad 8 Screen Digitizer Replacement - iFixit Repair Guide
Pull up the guide and jump forward to Step 43. They show the areas where the insulation needs to be and talk about using Kapton tape to keep the issue from happening.
So my suggestion would be to follow the guide through Step 43, then get out a magnifying glass and go over those flex cables with a fine tooth comb looking for tears or extreme bends the could account for the signals being disrupted.
Worst case you can probably get your iPad back in business by replacing the home button and digitizer, with the understanding that you'll be giving up Touch ID if that's of concern, but it's possible adding the insulation could get the digitizer working again. We won't know for sure about the home button until you have a chance to check the cable and see if it's in one piece.
Good luck; be sure to come on back and let us know what you find. Your experience may help the next person who comes along with the same problem.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 183
2 Comments
Has anything happened to your iPad recently, such as being exposed to liquid, dropped, a system update, etc.?
by Jerry Wheeler
@dadibrokeit
I dropped it a few years ago and it caused the digitizer screen to lift up, it can come completely off. I powered it on today for the first time since.
by Blue Koala
