The SRS-XG300 Wireless Speaker is a Bluetooth speaker created by Sony. This popular speaker is used to stream music and audio from a connected source device. This speaker is known for its powerful bass and producing vocal clarity.
AUDIO IN Jack does not recognize connection
Audio device output does not play on speaker. Bluetooth audio still works. Previously, inserting mini-stereo cable into AUDIO IN jack would prevent Bluetooth audio--this is not the case now. I have tried 3 different mini-stereo cables, audio device does output sound to earbuds through its mini stereo connection.
The Sony speaker did work two weeks ago. I went on trip and removed connections and placed speaker in its carrying case. I did not use the speaker during the trip. But it does not operate correctly upon my return home in its normal configuration.
Add a comment
1 Answer
Hi @davejones7666
Sounds like it may be a faulty audio jack.
Some audio jacks have internal changeover contacts that when operated by the insertion of the audio cable plug, operate to disconnect the BT audio input from the speaker and connect the audio cable input to the speaker instead.
Other types of audio jacks have a single internal make contact which operates to signal the audio controller on the board to switch the audio from the BT source to the audio input source.
I don't know which type is used in the speaker but here's the ifixit Sony SRS-XG300 repair guide that will help to gain access to the inside of the speaker so that you can check if the audio jack is working OK electrically when the cable is inserted.
Add a comment
Add your answer
Dave Jones will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 22
All Time: 158
