Released in 2015, the HP EliteBook 850 G2 is an update to the 850 G1, featuring newer processors and an optional touchscreen. Repair guides and detailed information can be found here.
My device doesnt powering on.
Device doesnt powering on..with battery or without battery, only charger.
When i press power on button,only keyboard lights turn on for a second, not ndisplay.after a second it turns off keyboard light too..
I opened the case.The fan spins when device got power.
4 Comments:
@dynamicrex does the fan spin normal, fast or just a little bit? What have you already checked?
by
Fast spining fan
by
Please Remove the RAM and check
by
@dynamicrex Have you attempted to remove/reinsert the hard drive in addition to the RAM?
by
Add a comment
This behavior usually points to a hardware power or motherboard issue. Since the keyboard backlight flashes briefly and the fan spins, the laptop is receiving power but failing POST. Try a hard reset first: unplug charger, remove battery, hold the power button for 30–40 seconds, then retry with charger only. Reseat RAM, SSD, and display cable. Test with one RAM stick if possible. If there’s no display even on an external monitor, the issue is likely a faulty motherboard, BIOS corruption, or power IC. In that case, professional repair or board replacement is required.
Add a comment
Well you can checkout the following video: https://www.youtube.com/watch?v=eHPTNKTg...
Add a comment
Add your answer
Dynamic Rex will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 137
