Seized Left Rear Wheel
my L/R wheel is seized,is it the rear hub unit bearing?
Donna, if it is a FWD model, it is possible that your hub has seized up. Of course, the only way to really determine this is to, jack up the car, remove the wheel, and remove the rear brake. Possibly that your break is causing this too. Check to make sure that the brake shoes from the parking brake are properly releasing, and the the brake caliper is not seized.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 1,585
7 Comments
What is your definition of "seized"? what does it do and what does it not do? Did this just start? What type of transmission does it have?
by oldturkey03 Share
wheel will not engage forward or reverse,just happened,auto transmittion
by Donna Share
is it FWD or AWD?
Its All Wheel Drive
by Donna Share
Same thing, check the brakes, see if you can release the brakes and if your wheel will turn. Possible seized bearing or seized rear differential :(
Show 2 more comments
