The Jura E8 is a fully automated espresso machine. This machine creates espresso and milk foam and can prepare different specialty drinks with three different water heat level for teas and hot chocolate.
Leaking water at bottom front right corner
What is the source of this leak, and can it be repaired?
Add a comment
1 Answer
You have to teardown the case. The source of the leak can be blown gasket or plastic part. Sometimes it can be fixed with applying a silicone gasket to the leaking part (not the corner cause in that case water will destroy inner components)
1 Comment:
Ok, will proceed as suggested. Thank you!
by
Add a comment
Add your answer
Barry Carroll will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 50
All Time: 317
