Up to 20% off select tools
Logitech Lift ergonomic mouse. Comes in black, white, and pink.
Left click button does work inappropriately,
Hi
I had used it around 10hrs every weekdays over two years, it is quite a long time use for daily basis because I am full time a drafter and designer. It started not reacting often with the left click button. yeah sometimes work sometimes not.
I've just replaced it with another new lift but if I can fix it, would glad.
Score 2
2 Comments
same for me. its a pity, i will reorder new one, but itl sure happen again. i didnt use it that much. but it happened after 2 years too
by Share
Right button is glitching for me. Purchased Aug 22.
by Share
Add a comment
Most Helpful Answer
@hyundongsung check your mouse and see if this is a mechanical or electrical issue. Use something like this teardown Logitech Lift Teardown to work on it. Check the plastic parts, the ribbon cable as well as the switch board. Let us know if you find anything that looks odd. Sometimes the top of the switches get wore down and the button does not reach deep enough to activate the switch. Adding a small piece of felt to the top of a switch can restore that function. If not, simply check the switches for function with a multimeter and see if they close the circuit when activated.
Score 4
Add a comment
Disassemble it and resolder the left mouse micro switch. There's a many different suppliers, but average micro standard is universal. You can replace this with soldering iron or station.
Add a comment
Add your answer
Hyundong Sung will be eternally grateful.
Past 24 Hours: 9
Past 7 Days: 73
Past 30 Days: 290
All Time: 3,555
