Repair information for the HP EliteBook 840 G3. This Hewlett-Packard laptop is designed for enterprise usage.
Why is my laptop not turning on?
Laptop Model: HP EliteBook 840 G3 (Energy Star)
OS: Windows 10
SSD: 256GB NVMe
RAM: 16GB
Issue Summary
After a recent Windows 10 update (auto-installed overnight on 10/09/2025), my laptop no longer boots properly.
When I press the power button:
  • Power button, keyboard backlight, and Caps Lock light all turn on.
  • The HP logo briefly appears on screen.
  • After that, the laptop powers off by itself.
  • This repeats in a power-on / power-off loop.
Troubleshooting Attempts
  1. Power drain reset – Held the power button for 30 seconds to discharge. No change.
  2. Battery removed – Tried running only on the adapter cable. Result:
    • Power and Caps Lock blink once, then system shuts off, looping again.
  3. CMOS reset – Removed and reinserted the CMOS battery. No effect.
  4. RAM reseating – Swapped RAM modules into different ports. Problem persists.
  5. BIOS recovery attempt – I already have the correct BIOS flashed onto a USB drive, but the system doesn’t stay on long enough to start recovery due to the boot loop.
  6. Pending test – Planning to test with a different RAM stick to rule out memory failure.
Current Situation
  • Laptop is stuck in a boot loop, unable to load BIOS recovery or Windows.
  • Only remaining suspected causes: RAM issue, motherboard fault, or BIOS corruption.
Anyone with the same issue and successfully fixed theirs?
Add a comment
1 Answer
What your symptoms suggest
  1. It powers on, lights flash, HP logo shows briefly, then power-off loop
    Not a dead motherboard (since you get the logo), but the handoff between firmware → POST → OS is failing.
  2. Caps Lock flashes once
    On HP laptops, blink codes matter. A single Caps Lock blink is usually CPU not functional or BIOS corruption, but since it gets to the logo, CPU is probably fine. This points more toward firmware/BIOS corruption.
  3. Windows update before issue
    Sometimes HP BIOS auto-updates via Windows Update (yes, really). If it failed or glitched, it leaves the system in exactly this loop.
✅ What you can try next
1. Force BIOS recovery the “HP way”
  • Plug in AC adapter.
  • Hold Windows + B keys, then press and hold the Power button for ~3–5 seconds.
  • Keep holding Windows + B until the screen lights up or you hear beeps.
  • This forces the system into HP BIOS recovery mode from USB or internal recovery partition.
  • Since you already prepped a USB with the BIOS, this is the method most likely to get it working.
(If Win+B doesn’t work, try Win+V instead — some EliteBooks use that combo.)
2. External monitor test
  • Just to rule out a display crash (rare but possible).
  • Connect HDMI or DisplayPort monitor, see if it shows more info before shutdown.
3. Test one RAM stick at a time
  • You mentioned you’ll try this — good call.
  • Boot loops with a quick logo flash often happen when RAM partially works (detected but failing during POST).
  • If you’ve got spare DDR4 SODIMM, even better for cross-test.
4. Reflash BIOS externally (last resort)
If BIOS recovery doesn’t kick in:
  • You’d need an external programmer (e.g., CH341A clip) to reflash the BIOS chip directly.
  • This is usually the fix if the system bricks after a Windows-pushed BIOS update.
  • Not DIY for most, but repair shops can do it quickly.
1 Comment:
I tried on a new Ram stick. Still had the same issue.
I still can't boot in into bios
The display has a little backlight when turning on so there isn't a display issue
The fan doesn't turn on at all
I may have to say, it is a motherboard problem
by
Add a comment
Add your answer
Ben Mugo Esq. will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 85
All Time: 399
