Repair and additional information for the Frigidaire GRFS2853A* refrigerator—a 2021 standalone refrigerator model with automatic defrosting, without built-in features such as a door dispenser or ice maker. This page covers information for model numbers matching the pattern GRFS2853A*.
My refrigerator continues beeping
My refrigerator is cooling properly, freezing properly, making ice properly, but the light on the door continuously flashes and it keeps beeping overtime the light comes on. And it is constant. Power cycling it doesn't work. Pulling the power for over an hour doesn't work. Holding the Crush to reset it didn't work. We are about to lose our minds. Any ideas?
4 Comments
Hi @tonyrogers
What is the full model number of the refrigerator?
What light is flashing?
by
GRFS2853AF0
It is the light in the door water/ice dispenser, under the temperature controls
by
@tonyrogers
Does the water dispenser work OK?
by
Everything works fine. Ice and water. Refrigerator is cooling and freezer is freezing. Just beeps and flashes the light.
by
Add a comment
1 Answer
Most Helpful Answer
Hi @tonyrogers
I don't know.
The only thing that I can suggest is that you use the service data sheet to run the diagnostic tests and check if any errors are shown.
Maybe perform the tests for the door switches, dispenser paddle and lights first if no errors show when first entering diagnostic mode.
Hopefully it is not a control board issue.
If you find the problem and it's a faulty part that needs replacing, here's the parts list that is useful.
Locate the wanted part in the list and note the part number that is shown for it. Search online for the part number only, to find suppliers that suit you best.
If you search on YouTube for (insert wanted part number) replacement, sometimes if you're lucky you'll find videos that show how to replace the part.
Score 1
1 Comment:
Thanks. I will check it out.
by
Add a comment
Add your answer
Tony Rogers will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 219
